How to Replace Felt Weatherstripping around Doors
what you'll need
- Felt weatherstripping
- Hammer
- Nails
- Tape measure
- Utility knife
Properly weatherstripping doors can make a big difference on how much air gets through the crack. It can cut down on utility bills and protect you from the elements better. You will know when it is time to replace weatherstripping as you will be able to feel a draft or see a gap. Here are the basics of how to replace felt weatherstripping on doors.
Step 1- Measure Around the Door
Take your tape measure and measure the distance around the perimeter of the door. Add a little extra to that figure to allow for error. This should tell you how much weatherstripping you need.
Step 2- Remove the Old Weatherstripping
Grab the weatherstripping and pull it out of the door frame. You may have to scrape it out with a utility knife in spots. You may also have to remove nails with the hammer to get it out.
Step 3- Cut to Fit
Once you get the weatherstripping, you need to cut it to fit. Take your tape measure and measure exactly to where you need to cut. Cut it with your utility knife.
Step 3- Adhere it to the Door Frame
Put the weatherstripping in place and then nail it into the door frame.
