Login Error
Close
How to Replace Recessed Lighting Trim
by DoItYourself Staff
what you'll need
  • Already installed recessed light fixtures
  • Circuit tester
  • Pliers (needle-nosed)
  • Screwdriver (type dependent on screws being used)
  • Measuring tape
Replacing recessed lighting trim is more of a tedious job than a difficult. In fact, the steps involved are so easy that you would not get discouraged to replace the trimming on multiple lights, which is often the case. Note that each recessed light fixture will vary slightly, meaning that any following details may nor may not apply to you. However, the general steps are constant, and should be heeded even though some trimming may be baffle, another not, etc. If you have read how to install these lights, than you may rest assure that replacing parts of the recessed lights are just as easy, if not easier.
Step 1 — Safety
The first step is a precaution and revolves around safety. Before anything, turn off the power. Understand that the mentioned “power” refers to the main power stemming from the breaker panel, and not the more convenient light switch across the room or so. In fact, use the circuit tester to double check the safety of the work station. Double check and measure the existing light fixtures to note the proper size for its replacements.
Step 2 — Removal
After the workplace is officially “safe,” you may now remove the light bulb from the heading of the recessed light and its trim. Most variations of these lights include snapped on trimming for decoration, and would not require any major tools. However, if the trimming is on tightly, do not hesitate to use pliers to manipulate and “convince” the trimming off. Next, use the pliers to remove anything holding the metal casting, which may be springs, clips, etc. Now, you can easily take off the casing. Next, unscrew the plate from the electrical box that is now exposed. Use the circuit tester to see if all the wires correspond accurately. After removing any wire nuts, disconnect the wires.
Step 3 — Replacing
Place the light fixture into the appropriate ceiling hole. Now, shove the fixture just enough to the side so that it physically rests upon the ceiling floor. It is suggested to shove the fixtures all in one, consistent direction, such as all of them being moved to the right, to save time and energy by having to search blindly for the resting fixture.
Step 4 — Wiring
Connect the appropriate with each corresponding wire inside the electrical box. For example, the white wires go with the white wires, black wires go with black wires, and so on, though most fixtures only need a black and white connection. It is easier to connect wires after stripping each end about three-fourths of an inch from its casing, exposing each individual strand.
Step 5 — Finishing Up
After re-positioning the fixtures into place, reattach the holdings, be them clips, springs, etc. Now it will be simple to snap any new decorative trim into place. Note that any trim replacement should be done before screwing back the bulb. Now, after reconnecting the power, test the bulbs and see if the new trimming is up to par.
 forum activity
