Login Error
Close
How to Replace Shower Pans
by DoItYourself Staff
what you'll need
  • New shower pan kit
  • Utility knife
  • Screwdrivers
  • Measuring tape
  • Caulk
  • Level
Replacing a shower base is a difficult and time consuming job. Fortunately, it is not something that you need to do very often. The only reason that you will need to replace a shower base is if it is leaking. Generally, it is not possible to repair a shower base, necessitating a complete replacement of the unit. You may also want consider replacing the entire shower cubicle at the same time, since you are going to have to remove all of it to access the shower pan. There is also a lot of other work involved as well, such as laying the new tiling or repairing any surrounding flooring or wall.
Step 1 – Make Necessary Preparations
Make sure that the water supply is turned off to the bathroom. For minimal risk, you will probably want to turn off the main water supply to the entire building before you start. Clear the area so that you can easily access the shower
Step 2 – Remove Old Shower Pan
Removing the old shower base is half of the job almost. Sometimes this can be more complicated than other installations, depending on the material that your shower base is made out of and the way it is installed. The first thing you will need to do is remove the shower doors which you should be able to slide and lift out of place. You will then need to remove the rest of the shower cubicle from the wall. It will probably be attached by screws. Remove these parts until all you have left is the shower base itself.
Step 3 – Install New Shower Pan
Place the new base over the shower drain pipe. Ensure that the floor is level beforehand. Since you are replacing an old shower, it should already be completely level. When you have at the base in place, attach it to the walls as directed by the manufacturer. The method you use will depend on the material that the shower base is made out of. A shower base kit will likely come with preset screw holes and screws allowing you to attach it in place easily. In other cases, you may be installing the shower base using a special mortar mix as directed by the manufacturer. Finally, fasten the flange to the wall making sure that the base flange is attached to any studs.
Step 4 – Install Drain
The drain should fit into the pipe in the center of the base. Make sure that the rubber washer is flat against the nut before you fasten them together. This will help to ensure that there is no leakage. Finally, screw the drain cover into the pan.
Step 5 – Apply Sealant
When the new shower pan has been properly fixed in place, apply silicone sealant to the edges to prevent any water from escaping. Leave the sealant to dry for at least 24 hours before using the shower.
 forum activity
