How to Replace the Gas Control Valve on Your Furnace
what you'll need
- New gas valve control
- Pipe wrenches, screw drivers, or pliers
- Protective clothing e.g. overalls, working gloves
It is important to regularly inspect the working condition of oil and gas heating furnaces, find out if gas control valve, control knobs, or thermocouples are in good condition. Proper maintenance of fireplaces allows efficient use of energy and fuel and it prevents the appliance from being a potential health hazard. Repair any parts in the furnace if they are damaged or faulty.
Some of the indications that the gas furnace might not be working properly include; poor production of heat-it can be too much or little, the fire keeps going off or does not light correctly, continuous flickering of the flame or appearance of an uneven flame or too much noise in the furnace. Any of these conditions call for inspection and repair of the source problem in the furnace.
Step1 - Get Necessary Tools and Equipment
Get the model of the gas valve control ypu need to buy. There are different designs and brands, confirm the model of the equipment from the old one and get an exact replacement from hardware or manufacturer stores. It is important to find an exact match because it provides a perfect fit for the furnace. This prevents leakage in the system.
Step 2 - Turn Off Gas Supply
Locate the gas control knob and turn it off. Find the gas control valve and switch it off as well. It prevents gas from leaking while replacing the old gas control valve. Do not proceed until the room is clear of gas, if there is a strong smell of gas in the house then call a plumber to correct the problem. However, turning off the control knob first and then the control valve effectively stops the supply of gas into the furnace.
Step3 - Remove the Old Gas Control Valve
Use a pipe wrench to unscrew the old equipment from the furnace’s system. Be careful no to damage gas supply pipes. Pliers or screw drivers can also be used. Use gentle, but firm movements until the old gas control valve is loose enough, use your hands to dismount the equipment from the system.
Step 4 - Make a Replacement
Take the new gas control valve and fix it using pliers or pipe wrenches. Watch out so that the pipes are not twisted or folded while fastening the equipment. Make sure that it is fast enough and secure so as to allow efficient flow of gas. Check that the control valve does not leak gas as well.
Turn on the gas flow system. Start by switching on the gas knob, and then the gas control valve. Confirm that the pressure is correct and regulate it is as it is required. Light the fireplace and check for the condition of the flame. It should be able to light a blue flame with a small yellow light.
