Login Error
Close
How to Replace the Grout around Your Bath Tile
by DoItYourself Staff
what you'll need
  • Grout saw
  • Mini vacuum
  • Small wire brush
  • Grout float
  • Grout
  • Sponge
  • Water
Bath tile tends to see a lot of abuse over the years. Whenever you shower, they get pummeled with water as well as soap and other chemicals. When you take a bath, water can slosh over the bath tiles. All of this abuse will cause the grout between and around bath tiles to become moldy or worn out. When grout becomes worn, it dries and cracks. When grout is damaged, it needs to be replaced with new grout. This is not a fun job, but it also is not a difficult one. The biggest problem associated with replacing grout between bath tiles is how long it takes. The job is tedious, but the following article will show you how to do it properly.
Step 1 – Cut the Grout
Removing grout between bath tiles is a process that is both time-consuming and delicate. In the past, you would use a small chisel and hammer to break the grout. This, however, can damage the bath tiles. A grout saw is the best choice to get through the grout. Turn the grout saw on and carefully cut the grout as close to the edge of the bath tiles as possible. You will need to repeat the process for the other side of the tile. The oscillation of the grout saw will remove the grout from between the tiles. Use the mini vacuum to suck up the grout.
Step 2 – Clean the Edges
No matter how well you work the grout saw, you will always be left with grout sticking to the side of bath tiles. In order to replace the grout, you will need to remove this excess. Slide the wire brush between the spaces and begin scrubbing it along the edges. The wire bristles will effectively remove the grout that is still sticking to the bath tiles. Use the vacuum to suck up the dust particles and then inspect the spaces again for grout. Repeat the process until the sides of the bath tiles are clean.
Step 3 – Wash Down
When you are satisfied that you have gotten all of the grout, clean the bath tiles. Use a damp sponge to wipe down the tiles. Let the tiles dry on their own. Removing dust and other particles is important to maintaining a clean grout that will bond correctly.
Step 4 – Grout the Bath Tiles
Applying grout is relatively simple. Mix the material according to the directions on the package if not using ready-made grout. Use the grout float to scoop up the grout and slap it over the bath tiles. Using the grout float, smooth the grout over the tiles. Use firm, even pressure to press the grout between the spaces. Occasionally, use a damp sponge to wipe down the bath tiles. This removes the grout haze that may form over the tiles. Use as much grout as needed to finish sufficiently the job of replacing the bath tiles' grout. Wait for several days until the grout dries.
 forum activity
