Login Error
Close
How to Reset a Garage Door Keypad Opener
by DoItYourself Staff
A garage door opener keypad gives enables you to access your garage. The garage door keypad is located outside the garage door and can be activated and deactivated by providing your specific personal identification number.
Resetting your Garage Door Opener Keypad
To reset your garage door opener keypad all you have to do is press the “Learn” button located at the back or sides of the motor unit of your electronic garage door opener. After pressing the learn button you will see an LED light steadily glowing for about 30 seconds. Enter your new Personal Identification Number (PIN), then press the “Enter” button. Once you released the “Enter” button and you see the LED light blink in the motor unit of your electronic garage door opener this means that you have successfully reset your garage door keypad opener.
Garage Door Security
It is important to reset your garage door opener keypad to prevent unwanted entry to your garage. Choose more than 4 numbers for your PIN code. Do not use your birth date or the date of your wedding anniversary or any other digits associated with your personal information. Instead, choose a random number that you can easily remember.
 forum activity
