Login Error
Close
How to Reweave Wicker Furniture
by DoItYourself Staff
what you'll need
  • Hammer
  • Tacks
  • Scissors
  • Wicker
Wicker Furniture has been known to sometimes break or fall apart. It can be quite expensive to try to repair it. A lot of the time, you will find that you will only need to reweave the wicker furniture. If this is the case, this is not a difficult task to accomplish. As long as you have the right tools and the know-how, you will have no issues when it comes to reweaving your wicker furniture.
Step 1 – Get the Right Wicker
You will first need to figure out the right wicker that you will need. If you are reweaving your wicker, you will of course want it all to be the same so it will look like it did before. Any nearby arts and crafts store will be able to provide you with a large selection to choose from. If possible, bring some of the wicker from the furniture so that you will be able to compare.
Step 2 – Secure
You will need to get your tacks and tack the end of the new wicker pieces. Be sure that they are as close to the old pieces as they can get. If you wish, you can also use glue or simply tuck the wicker in. Just be sure that the glue is dry before you use it or that the piece is tucked in securely.
Step 3 – Weave
Once you have the piece secured, you will begin by weaving it in and out of your furniture. Do this until the entire gap is filled. Try to make the weave as close as the original as possible. This will help to make it blend in better. From there, use your tacks, your glue or simply wrap or tuck the end so that it will not unravel.
Step 4 – Hints
When you are purchasing your replacement wicker, it is always a good idea that you purchase wicker that is at least 5 inches longer than what you are replacing. This will help you to tuck or wrap the excess in to prevent unraveling. Also be sure that you soak the wicker for at least a 1/2 hour. This will help the pieces to become flexible and will help you to weave them easily. When you are soaking, use a drop or two of a mild detergent. This will help to keep mold or any form of bacteria from forming.
Step 5 – Proper Care
While sometimes, it is inevitable that your wicker furniture needs to be repaired in some way, there are certain steps that you can take to keep it looking newer, longer. One of the biggest things that can harm your wicker furniture is any form of direct heat. Keep your wicker furniture away from the sun and far from fireplaces. It is important to remember that wicker does not do well when it is in the elements for a prolonged period of time.
If your wicker furniture is an antique, then you will need to get professional work done to it. Doing the work yourself without experience can diminish the value of your wicker.
 forum activity
