Login Error
Close
How to Run Wire behind a Baseboard Part 3
by DoItYourself Staff
what you'll need
  • Tape Measure
  • Hand held drill
  • Cable
  • Utility knife
  • Finishing nails
  • Chalk or pencil
  • Plastic Zip Ties
  • Paint brush
  • Paint
  • Sand paper
  • Shimmering shingles
This 3rd part in the series of articles on how to run wire behind a baseboard will summarize everything you have learned so far and instruct you on how to finish the project. Not much farther to go; so, let's get started.
Step 1 - Plan and Cut
In section one of this series, you learned that the first thing you need to do is to get the measurement of your work area. Use a tape measure and get the dimensions of the room. After getting the measurements, make a plan first on how you will install the wires. This makes the process easier for you.
After making the plan, get your knife and slowly cut the area between the baseboard and the wall. This will require force and pressure. But always remember to cut this slowly to avoid incurring any damages. After cutting, use your putty knife to lift the baseboard. Again, this will require force. Take note if there are any loose screws. Use your long pliers to remove the screws and sand the surface to make sure all areas are even.
Step 2 - Make Holes
You also learned that after cleaning the area, you need to make a main hole to insert the cable wires. But you will also need to make other small holes where you will pass the wire through the studs that support the drywall and baseboard. Then, you can pass the wire through the holes in the studs. Bind groups of wires together with zip ties so they are easier to work with.
Step 3 - Reattach Drywall
If you are going to attach drywall, you will need to attach starting from the ceiling, working your way down to the floor. Put fasteners every 8 inches to secure the wall. If you plan to use nails, make sure to double the nail to make sure the drywall will not wobble as you work your way down. Bottom panels should reach the floor. Then, you will need to finish the drywall with tape and drywall mud before painting. If you simply removed sections of the drywall to reach the interior stud wall, you can simply cut new pieces; attach them to the wall studs; and then tape and mud the drywall pieces. Take your time in finishing and sanding the mudded drywall as this will result in a much cleaner and professional job when it is time to paint.
Step 4- Finish the Wall
Insert the cable wires. Pull them through the holes you created in the studs and then cover with drywall. If you will need to install outlets or switches in the area, make allowances when cutting the cable length to be installed behind the baseboards. Make sure to mark locations for outlets on drywall next to the stud where the outlet will be attached. This will make finding the location easier and help you to avoid removing and replacing drywall by guessing.
project steps
 forum activity
