These steps will help you safely install your gas dryer. Start by purchasing your supplies.
Supplies You Need for Your Gas Dryer Installation
- A shutoff valve – either 1/2” or 3/8” depending on your pipes
- A dryer installation kit
- A pipe wrench that will fit your pipes
- A stainless steel connector
- Thread lube
- Sealant
Make sure that your outlet and the requirement of your gas dryer are the same. Once you have everything you’ll need it’s time to get started.
Step 1: Turn Off the Gas
You need to turn off the main supply for you gas, right at the meter. If the supply pipe has a cap, you will need a pipe wrench to remove the cap on the gas pipe where it comes out of the wall.
If the gas supply has been installed with the wrong size shutoff valve, you will need to use your pipe wrench to hold the pipe so it doesn’t turn while you remove the shut off valve.
Step 2: Install the Gas Connections for a Gas Dryer
The instructions for the installation of the gas connection parts for your gas dryer should be included with your gas dryer installation kit. If you are unsure, you should always contact your gas provider. Most gas providers offer reasonable installation fees.
Professionals as well as some do it yourself people will install the gas shut off valve with the gas on. If you aren’t sure if you can install your gas dryer with the gas on.
Step 3 - Shut the Electrical Power Off
Before doing any repairs or before doing a new install make sure the power is turned off to the appliance. Shut the power off right at the breaker box.
Step 4 - The Vent Hole
Check your vent hole on your gas dryer to make sure it matches the vent hole in your home. If it doesn’t you will need to cut a new dryer vent hole.
Step 5 - Clean Up
Wash the floor and let dry where the gas dryer is going to sit and the surrounding area.
Step 6: Pipe Dope
Put the pipe dope on the threads then take your stainless steel connector and screw it to the pipe.
Step 7 - Check for Leaks
Once the dryer gas lines are hooked up check for leaks. Mix 50% water with 50% liquid dish soap. Put the solution on the gas connections you have just installed. Then turn on the gas. If you see bubbles, it means you have a leak. Tighten and test again.
Step 8 - Fasten the Vent Hose
Fasten the vent housing to the duct then place your hose clamp on and tighten. Keep your vent hose to the shortest length possible to increase drying time and the efficiency of your gas dryer.
Step 9 - Almost Done
It’s time to plug your gas dryer in, attach the lose end of the vent hose, and then push the dryer back into place. Keep it at least 3” off the wall for circulation.
Step 10 - Turn it On
Turn the gas on and the break on. It’s time to test drive your new gas dryer.
Questions of a Do It Yourself nature should be submitted to our
