How to Safely Remove Silicone Adhesive Sealant from Skin
what you'll need
- Cotton balls
- Soap
- Nail polish remover
If your skin has recently come into contact with silicone adhesive sealant, you may be wondering how to go about removing it. If so, read on to learn everything you'll need to know about safely removing silicone adhesive sealant from skin.
Step 1 - Prep Your Skin
Begin the silicone adhesive sealant removal process by vigorously scrubbing the infected area with soap and water. After three or four washings, use your hands to peel away any loosened pieces of sealant before continuing on to the next step.
Step 2 - Apply Your Nail Polish Remover
Now that you've carried out the preliminary washing, soak a cotton ball in nail polish remover and proceed to rub it over the infected area. Make sure to perform this step in a well-ventilated environment, as the fumes emitted by most brands of nail polish remover can be overpowering, particularly if you're exposed to them for long periods. Also, make sure acetone is an active ingredient in your nail polish remover, as this particular chemical will play a pivotal role in getting the sealant off your skin. Continue to rub your skin with nail polish remover until the sealant begins to loosen, at which point you will need to peel it off.
Step 3 - Perform a Post-Removal Cleaning
Once all the sealant has been washed away, clean the previously infected area of your skin with soap and water. Make sure all traces of sealant are gone before deeming the removal process a success.
