How to Seal an Undermount Kitchen Sink
what you'll need
- 100% Silicone sealant
- Denatured alcohol
- Rags
Undermount kitchen sinks are beautiful and modern additions to any kitchen upgrade. Sealing an undermount sink is straightforward, and requires only a few simple steps.
Step 1 - Prepare the Counterop
If this is a new installation, start with the countertop turned upside down on a sturdy surface. Dry fit the sink and mark the placement. Clean the underside of the counter thoroughly with the denatured alcohol. Even small amounts of dust or debris will compromise the sealant. If you are replacing the sealant on an existing undermount sink, remove the old sealant as carefully as possible to avoid scratching or damaging the fixture. Clean around the juncture of the counter and sink as much as you can, getting into as many of the tight spots as possible with the alcohol. Let the area air dry thoroughly.
Step 2 - Apply Sealant
Apply a steady bead of silicone around the edge of the countertop (if new install) or around the juncture between the counter and sink (if existing). Place the sink and clamp it into place. Allow the sealant to dry overnight before finishing the installation or using the sink.
Step 3 - Clean Up
Use a damp rag to clean up any oozing sealant or drips. Silicone will scrape away easily when dry.
