How to Seal Mobile Home Roofing
what you'll need
- Roofing shingles
- Sealant
- Tar paper
- Flashing
- Metal snips
- Roofing nails
- Hammer
- Ladder
- Staple gun
Adding sealant to mobile home roofing can be done by following the procedures for a regular roof installation. Sealing your mobile home has some advantages to other type of roofs that you install. The process, tools and materials for this job are described below.
If you are intending to do this project, employ an assistant to help you with the installation as you will be working high off the ground.
Step 1: Rent a Dumpster
For this project you need to rent a dumpster into which you can toss the old roofing materials. This can be rented in most communities from the waste collection department. Be sure to have the dumpster delivered and placed in an area of your yard, under tarps that makes it easier to catch the loose materials that you remove from the roof.
Step 2: Climb on the Roof
You will need a ladder that is tall enough to allow you to easily climb on your roof in order to remove the existing shingles. This ladder should be purchased or borrowed from a neighbor and inspected to make sure that it is durable enough to accommodate your weight and allow you to accomplish this task.
Take your shovel or hoe and climb on the ladder to the roof.
Step 3: Take Apart the Roof
Use the shovel or hoe to remove the roofing material. Work carefully when at the edge of the roof to prevent any injury or harm to yourself. You should wear safety glasses while you work since a lot of loose material will be flying toward you. The material should be tossed into a waste receptacle below you while you work.
Step 4: Remove all Nails and Loose Material
You will need to get on your knees and remove all of the loose nails and other materials that is remaining on the roof. This is a tedious process that will take time and require you to carefully go over every inch of the roof to remove the material. Throw the loose material away in the dumpster.
Step 5: Install Tar Paper
Roll out tar paper on the roof. This will act as a barrier to keep water from leaking through the roof. The tar paper will be affixed to the roof using a staple gun.
Step 6: Attach the Roof Shingles and Apply Seal
Working in rows attach the Gambrel roof shingles to the roof. The shingles should have a lip or attachment that will allow you to nail them down on a nailer strip that you installed over the tar paper. Work carefully in order to attach the entire row before moving on to the next.
With the roof attached, apply the sealant to finish the job.
