How to Seal off Moisture with Basement Vapor Barrier Paint
what you'll need
- Waterproof paint
- Everyday paint
- Paint brush
The basement vapor barrier paint is a modern development on water barrier techniques. In the basement, water vapor can travel up from the ground, and affect the walls and floor in the lower half of your home. It is common to use plastic sheeting as a basement vapor barrier, but waterproof paint will work just as well. This job can be done in a matter of hours, following a few simple guidelines to get it done quickly and easily.
Step 1 - Prepare the Area
You will need to prepare the area where the paint will be laid. You can do this by cleaning the floor, sweeping any dirt and debris away.
Step 2 - Add the Basement Vapor Barrier Paint
The basement vapor barrier paint is typically applied as a primer, below another coat of paint. You may color it as you wish, although it can also be left as a white paint. Begin by painting along the edges of the walls, and then move the paint towards the center of the room, ensuring that you can leave the basement at the end. Leave the paint to dry, and the apply a coat of ordinary gloss paint. Both paints can be added using a standard paintbrush.
