Login Error
Close
How to Seal Tumbled Marble Tiles
by DoItYourself Staff
what you'll need
  • Marble sealer
  • All-natural stone cleaner
  • Small paintbrush
  • Nonabrasive washcloth
  • Breathing mask
  • Broom and dustpan
  • Vacuum cleaner
If you're looking for an great way to protect your tumbled marble tiles from falling victim to excess moisture, you should consider sealing them. Well-sealed tumbled marble tiles will be considerably more resistant to mold, mildew and other tile-based filth than unsealed tiles.
Step 1 - Clean Your Tumbled Marble Tiles
Make sure to remove any dust deposits from your tiles before proceeding to seal them. Using a broom and dustpan, thoroughly sweep the tiled area until it is completely dust-free. Alternatively, this step can be performed with a vacuum cleaner that features brush attachments. Next, remove any dirt from the tiles with the aid of an all-natural stone cleaner and a nonabrasive washcloth. It's important that your stone cleaner be all-natural, as a standard stone cleaner may have a potentially dangerous chemical reaction when combined with your sealer.
Step 2 - Apply Your Sealer
With your tiles clean, it's time to apply your sealer. If you selected a spray-on sealer, spray it across the tiled area, then smooth it out with a nonabrasive washcloth or small paintbrush. If the sealer you purchased needs to be manually applied, use a small paintbrush to spread it evenly across the tiled area. Make sure to perform this step in a well-ventilated area, and, if you feel weak from the sealer fumes, wear a breathing mask. Lastly, allow the sealer to dry for the amount of time listed on its box.
 forum activity
