Login Error
Close
How To Select A Soldering Iron
by DoItYourself Staff
A good soldering iron is one that will allow you to secure a thin lead on a circuit board without causing any damage to its additional components, provide you adequate wattage, an appropriate tip and sufficient temperate. The following are the steps that will guide you into selecting a soldering iron:
Step 1: Make an assessment of the work you have planned. Most soldering irons can use a variety of tips, but many come with different temperature controls and wattages.
Step 2: Asses your budget. If your need is of specialty equipment, then you need to be prepared that the price tag may be a few hundred dollars on an appropriate soldiering station.
Step 3: Choosing a simple soldering gun or soldering pencil that uses a direct electrical connection may be useful in helping you complete specific DIY jobs in your home.
Step 4: You can choose a rechargeable, cordless unit and a solder station of precise, fine work. Circuit boards can have fine wire tips work well on them.
Step 5:
If you require heavy-duty work to be done, then a soldering iron with a higher wattage is required, more than 25-watts, at least. If your work requires continuous use, then consider a temperature-controlled soldering iron, which will keep the temperature at a constant level. In addition, if you need to use a soldering tool on regular basis, you can consider upgrading to a soldering station.
 forum activity
