How To Soundproof A Ceiling
what you'll need
- Ladder
- Fiberglass insulation
- Dense foam tiles
- Acoustical caulk
- Isolation clips
Creating a soundproof ceiling is easier than you may think. It does require a bit of time, effort and skill, however, it is certainly a project worth undertaking if you are plagued by constant noise from above. This is not a project you should undertake alone however, as drywall can be quite heavy; grab a friend and follow these instructions to soundproof your ceiling:
How to Soundproof Your Ceiling
Step 1 – Your ceiling must be completely exposed to begin soundproofing it. If there is any drywall or anything else underneath, it need to be removed at this time so that only the wood struts are exposed. Keep the drywall handy and intact in a safe location out of the way, as it will be easier to use your existing drywall than cutting new sheets. Gather all your materials for soundproofing. Be sure to change into a pair of jeans and long sleeves when working on your soundproof ceiling, as fiberglass can be very irritating to sensitive skin.
Step 2 – Tightly pack the foam insulation into the spaces between the exposed wooded struts. This is your ceiling’s first line of defense against sound. Generally most normal sound activity can be blocked with R12 or R13 foam insulation. The R index refers to the foam’s density and its ability to block sound.
Step 3 – Inspect your ceiling for any small openings that may need to be sealed. Just a slight space can leak a considerable amount of sound, so use the acoustical caulk to seal any cracks or small holes that you can find. Just a dab on a hole to cover it will be enough to seal it.
Step 4 – Place a layer of dense foam tiles over your ceiling. There are a number of companies that sell previously constructed soundproof ceiling tiles and this is your best and easiest option to use for this step. These type of ceiling tiles will fit into any ceiling without falling loose. Sounds travels slower through objects the denser they are, so be sure to use ceiling tiles that are as dense as you think you will need to block out your particular sound issue.
Step 5 – Again use the acoustical caulk to seal any cracks or spaces that you can find in the ceiling. Making sure at this stage that the entire ceiling is airtight is very important, so look closely and be thorough.
Step 6 – Replace your ceiling drywall using isolation clips to separate the drywall slightly from the wooden struts and other layers of soundproofing materials. This is called a floating ceiling and this technique will help to lessen the noises caused by vibrations and other noises above.
By following these steps, you can create a nicely soundproofed ceiling with just a moderate amount of work. Be meticulous and thorough and don’t cut any corners, as it just takes a very small space to leech sound through the walls.
