Login Error
Close
How to Stain Unfinished Bathroom Cabinets
by DoItYourself Staff
what you'll need
  • Stain
  • Brush
  • Soft cloth
  • Water
  • Sealer
  • Sandpaper
There are a number of ways in which you can beautify your new, unfinished bathroom cabinets. Before staining the cabinets, careful selection is necessary. By choosing the right stain for the cabinets and applying it correctly, you can achieve a great look that will last for many years.
Step 1 – Choose the Correct Stain
Depending on the type of wood and its color, you must choose the most appropriate stain. If you want the grain of the wood to show through you can apply a clear stain. Darker woods require a dark colored stain, whereas lighter woods can use any color. There are many different types of stains, such as organic, oil based, water based, acrylic stains and stains with sealer. Consider the ease of application as well. Some stains must be wiped onto the surface, whereas others can be applied with a brush or sprayed on. Once you apply the stain, you must also apply a sealer, unless you have chosen a stain that includes sealer.
Step 2 – Prepare the Surface
If you have new, unfinished cabinets, it is preferable to stain all the parts before assembling them together. It is easier to stain all the parts evenly to get a better finish. Before applying the stain, you must have a smooth surface to work on. Use a rougher variety of sandpaper to smooth the wood. Sand the wood in the direction of the grain. Afterward, finish off with a finer type of sandpaper. Clean all the sawdust from the wood and wipe with a damp cloth if necessary. Keep all the parts on a stable surface so that you can easily stain them. It is preferable to do the staining in a well-ventilated environment.
Step 3 – Apply the Stain
Read the application instructions carefully beforehand. If you have a piece of scrap wood, it is best to test out the stain on it before you apply it on the cabinets. Once you are ready to apply the stain, dip the brush in the stain and apply light, even coats on the cabinets. If there is any overflow or excess, take a clean, soft cloth, dip in stain and wipe off the excess stain carefully so that you achieve an even finish. Let the first coat dry and then apply subsequent coats as necessary.
Step 4 – Apply a Final Finish
Once the stain is completely dry, inspect the cabinets carefully for any signs of raised grain. This is a common occurrence after staining and may give an uneven look. You can very lightly sand such patches to smooth them out. Take care to avoid removing any stain, because if you do, you will have to apply another coat. Once the surface is smooth, you can apply sealer. You can choose from polyurethane varnish or any other type of sealer. Before application, ensure that the sealer is compatible with the applied stain. Apply the sealer with a brush and let it dry, after which you can apply more coats.
 forum activity
