How to Steady Your Workplace with Toggle Clamps
what you'll need
- Toggle clamps
- Spirit level
- Tape measure
- Paper and pen
Whether you are a hobbyist or carry out do it yourself projects in the home, you will find that toggle clamps are beneficial to help keep your workspace steady. This is beneficial to help you prevent making mistakes while you are working. It is necessary to take the steps to fit the clamps correctly to ensure that they are effective.
Step 1 – Inspection
Examining the workplace that you need to stabilize will be the necessary first step of fitting toggle clamps. This will help you to determine the extent of the work necessary to rectify the table to allow you to work on it. You will also be able to check how much space you have to fit the clamps to ensure that you choose the right ones for the task. Bear in mind that there will need to be enough room for the clamps on the worktop to accommodate the clamps, as well as around it. If necessary, use a tape measure to make a note of the dimensions and retain this while obtaining the clamps.
Step 2 – Obtain Clamps
Once you have all the necessary details about the workplace, you will be in a position to obtain suitable clamps. You will find varieties that can be fitted horizontally, vertically or diagonally. Further, the manner in which the clamp is operated will also vary, from levers to buttons to dials. Others you will find can be squeezed into position. Make sure that you have the ability to operate the clamps before you make a purchase. Similarly, you should also check that the thickness and force of the clamp is sufficient to handle the workplace.
Step 3 – Fit Clamps
Choose the place where you want to fit the clamps and make any necessary adjustments to the workplace to ensure that it is ready for the clamps. In many cases, you will be required to open the toggle clamps before positioning them in the correct place, fixing them in place. The mechanism will then need to be compressed using the operating method, which may mean pulling a lever past a central point, twisting a dial or depressing a button or plunger. Set the clamp firmly without it being overly tightened, which will create too much pressure and cause a misalignment. Further to the examination you undertook previously, use the results to fit the correct number of clamps for the task. Place them where they will not be in the way.
Step 4 – Adjust
After they have been placed, it is prudent to test the effectiveness of the toggle clamps to ensure they have been fitted correctly. Use a spirit level to determine whether the workplace is level and make any necessary adjustments if it is misaligned by releasing and adjusting the clamps. Whether or not they appear to have been fitted correctly, you should try working on the workplace to determine whether it will remain steady.
