How to Stop the Squeaking Noise from Your Bathroom Door
what you'll need
- Hammer
- Slotted tip screwdriver
- A newspaper or piece of cloth
- Steel wool
- Nail
- Spray lubricant
- Motorcycle chain lubricant
That squeaking noise coming from your bathroom door can be really annoying, especially if someone is using the bathroom at night. Silencing the bathroom door is not a difficult task, and there are many ways to do it. The easiest is dripping cooking oil on the hinges; however, this will stop the squeaks for only a short while. The hinges will get very sticky and will allow dirt buildup. Bathroom doors get squeaky for a number of reasons, all related to hinges: corrosion, rust, poor painting jobs or poor quality lubricants. You can fix the problem by properly lubricating the hinges and the hinge pins. For best results, you should first clean and protect them against rust and corrosion, which are caused by the humidity in the bathroom.
Step 1 – Remove the Pin
Remove the first pin from the hinges. Place a nail underneath the pin and tap it up with a hammer. When the pin is forced up, take it out. If the design of the hinge does not allow this, use a slotted tip screwdriver. Insert the screwdriver’s tip beneath the pin’s head and tap the screwdriver’s handle with the hammer. Continue tapping until you can pull the pin out with your fingers. Be careful when you remove the pins to avoid hurting yourself. Take out and work on one pin at the time.
Step 2 – Clean the Pin
Place the pin horizontally on the newspaper. In case the pin is corroded and rusted, clean it thoroughly. It might have traces of paint and old lubricant. You should use steel wool or emery cloth to remove all debris. The surface of the pin should be smooth when you apply the spray lubricant. The lubricant is very efficient in degreasing metal and preventing rust and corrosion. The pins and hinges, as well as all metal objects in your bathroom, are exposed to temperature changes and humidity. Therefore, they need to be properly protected against rust and corrosion.
Step 3 – Clean the Hinges
Clean the hinges with steel wool. Apply some spray lubricant on the hinges as well.
Step 4 – Apply Lubricant
Lubricate the pins and the hinges with motorcycle chain lubricant. Distribute the lubricant up and down the hinges. Motorcycle chain lubricant is very efficient. It protects metal against temperature changes and humidity. You could also use petroleum jelly, but this will collect dust and allow dirt buildup. Cooking oil is not a good solution because it gets sticky and can also release bad odors. Graphite powder can also prevent squeaking but may spread, leaving a dark mist all over the place.
Step 5 – Reinsert the Pin
Reinsert the pin into the hinge. Repeat steps 1 to 5 with the next pins and hinges. Make sure that you clean and lubricate all the hinges of the bathroom door.
