How to Take Full Advantage of a Graphics Card
what you'll need
- A Computer Manual
- A Microprocessor Booster Chip
- An Operating System Upgrade
- A New Computer
Your computer's graphics card is used to transfer information from the processor to the screen. The graphics card also provides your computer screen with images and computer gaming capability, if you are involved in such activities as Word, Warcraft and other online gaming communities.
Learning how to take full advantage of your computer graphics card depends a lot on the type of computer that you have and its capability to properly operate the graphics card. Here are some steps that may assist you in using your computer graphics card to its fullest potential and get the most out of your computing experience.
Step 1: Refer to Your Computer's Manual
First, you should have a fairly newer computer model in order for the new graphics cards to make sense to your computer. Check the age of your current computer to determine if it is adequate enough to meet the requirements of the graphics card that you are looking to install.
Get a copy of the manual for your computer to locate your microprocessor, or motherboard. The graphics card is connected to the microprocessor where it sends its instructions to create the graphical image. The manual will help you identify the type of microprocessor you have and whether you should consider replacing it. If you need to replace the microprocessor, you may again consider the value in purchasing a new machine.
Step 2: Insert a Booster Chip
Purchase a math co-processor chip or booster that will help improve the performance of your graphics card. The math co-processor will allow the computer to process algorithms and other mathematical calculations that will make graphics appear faster on your screen.
There should be an expansion slot on the microprocessor that will allow for the insertion of the math co-processor chip. Follow the instructions carefully that came with the packaging in order to properly install the chip.
Step 3: Upgrade Operating System
After installing the math co-processor chip, you will need to upgrade your operating system. If you are running an earlier version of Windows, upgrade to the most current version of the software. This may also help your graphics card work better and function at its peak performance level.
Step 5: Avoid "Overclocking"
Overclocking is a process where you change the settings on your internal clock in order to make the microprocessor work faster. By speeding up the processor, the graphics card will work much better than it did before.
The problem with overclocking is that it will cause the computer to generate much more heat and can possible cause the processor and other internal circuits to fail. If it is determined that the failure was due to overclocking (and it will be), the manufacturer’s warrant that came with your computer will be voided.
