Login Error
Close
How to Test a Low-Voltage Lighting Transformer
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Volt ohmmeter
  • Step ladder
To ensure that a low voltage lighting transformer is working correctly to control the lights, there may be occasions when it is necessary to test it. Following a few steps will enable you to complete this process effectively.
Step 1 – Prepare
Begin the process of testing the low voltage lighting transformer by switching off the power supply that serves it. If the transformer is in a high location, position the ladder securely before climbing it to remove the cover. If you have retained the manual that relates to the transformer, it will be useful to check it to determine what to expect.
Step 2 – Apply Wires
You will find that the low voltage lighting transformer comprises two test wires. The red one must be inserted into the recess marked ‘ohms’ on the meter while the black one can be inserted into the common recess.
Step 3 – Check Reading
When testing a low voltage lighting transformer, you are looking for reading that displays a closed circuit. If you get a reading of zero ohms, you have the correct result. Anything other than this means that there is an open circuit and the transformer must be replaced.
 forum activity
