Login Error
Close
How to Tile Over Sheetrock
by DoItYourself Staff
what you'll need
  • Joint compound
  • Putty knife
  • Primer or sealant
  • Tile adhesive
  • Trowel
  • Tiles
  • Tile spacers
  • Tile cutter
  • Grout
  • Grout float
  • Sponge
  • Level
  • Paint roller
Sheetrock or drywall is no different a surface to place tiles over than wood, plaster, cement or other materials that is used for walls. If you are tiling an area that is other than in the bathroom, tiles can be applied directly to the sheetrock simply and easily. The wall has to simply be prepared in order to apply the tiles properly. If you are looking to place tiles on a sheetrock wall that is inside your bathroom, you will need to use a vapor barrier or some type of backing in order to prevent the sheetrock from getting wet, which will cause it to deteriorate.
Step 1 - Obtain Materials from Home Improvement Center
Purchase the joint compound, putty knife, primer, adhesive and other materials needed to apply tile to your sheetrock walls from a home improvement center. You may also be able to find the tiles needed to accomplish this job. You can also go to a carpet and tile store to find tiles for your sheetrock wall.
Step 2 - Fill Holes
Using the joint compound and putty knife, fill all holes and punctures in the sheetrock. Scrape the blade of the putty knife over the joint compound in order to smooth it out and avoid having to sand the wall. Allow the joint compound to dry completely before moving on to the next step.
Step 3 - Apply Primer to the Sheetrock
Apply a coat of primer sealant to the wall. Roll the sealant onto the wall evenly, using a paint roller. Avoid drips that might cause the tiles to hang unevenly.
Step 4 - Place Tile Adhesive on the Sheetrock
Take the tile adhesive and putty knife and apply it to the sheetrock. Work in sections at first since the adhesive can dry quickly. Spread the adhesive evenly in the small working area that you are going to apply the tiles. Once you spread the adhesive to the tiles, press the tiles into place. Use the tile spacer to keep the tiles separate from each other as you press them in place against the sheetrock.
Use the tile cutter to make cuts in order to fit the tiles to the end of the sheetrock. Be sure to measure the tile correctly and operate the tile cutter according to instructions, keeping fingers and clothing away from the cutting surface.
Step 5 - Grout Tile
Allow the tile to dry for 1 day after placing it on the sheetrock. In this step, you need a grout float and grout that is either redi-mix or that you need to prepare for the tile. The tile grout will fill the space between the tile installation. Work the grout into the tile using the float, spreading a generous amount in between the grout lines. Use a wet sponge after the grout has been put in to clean off the excess grout and once again after the grout dries to clean the tiles.
 forum activity
