Login Error
Close
How to Transplant a Black-Eyed Susan
by DoItYourself Staff
what you'll need
  • Garden spade
  • Water hose
  • Organic mulch
  • Super phosphate or animal manure
  • All-purpose fertilizer
If you need to move her transplant your black-eyed Susan flowers, you should know that these hardy perennials handle being moved to a new location rather well. Transplanting black-eyed Susan plants is not that difficult, and you can usually complete the job in a couple of hours. So, here is a step-by-step guide to help you transplant your black-eyed Susan plants.
Step 1 - Choose an Appropriate Time
It is easiest to transplant black-eyed Susan plants after all of the flowers and bloom die away for the season; however, you can transplant them when they are in bloom. If you choose to transplant the black-eyed Susan plants while in bloom, you should be aware that the flowers and blooms will probably wither away. Generally speaking, is a good idea to transplant black-eyed Susan flowers in late Fall well before the first frost.
Step 2 - Soak the Black-Eyed Susan Plants
Use a water hose to thoroughly saturate the plant and soil area where your black-eyed Susan is planted. Water the area slowly and allow it to thoroughly saturate the root system of the plant to be moved. Allow the water to seep into the soil for about 30 minutes to 1 hour before digging out the plant. This will help loosen the root system of the plant and make it easier to remove
Step 3 - Dig Out the Plant
Begin at the drip line of the black Susan plant and carefully dig out as much of the root system as you can. If you must cut parts of the root system, make sure to create straight clean cuts that will not damage the roots too much. Carefully remove the plant from the hole, and then gently shake loose any dirt that clings to the root ball. Also gently remove any dead growth or woody portions of the crown or root system.
Step 4 - Prepare the New Location
Prepare the new location for your black-eyed Susan plants by turning the soil with all-purpose fertilizer and adding super phosphate or animal manure. Dig holes in the soil that are the same depth as the hole in the original location. Make sure to allow adequate spacing for your black Susan plants if you'll be transplanting two or more.
Step 5 - Replant the Black-Eyed Susan
Insert the plants into the new holes and pack soil around them tight enough to support the plant and allow it to stand on its own.
Step 6 - Add Organic Mulch
Add 2 to 3 inches of organic mulch to help retain moisture in the soil and help keep the root system protected while it reestablishes.
Step 7 - Add Fertilizer
Apply more all-purpose fertilizer to help provide much needed nutrients for the new newly transplanted black-eyed Susan flower.
Step 8 – Water the Transplants
Thoroughly water the newly transplanted black-eyed Susan by adding water in increments to ensure that the root system is thoroughly watered but not saturated. You will need to frequentl water the black-eyed Susan plant until the root system again is established.
 forum activity
