How to Troubleshoot a Heat Pump that's not Cooling
what you'll need
- Air filters
- Low pressure hose
Keeping your heat pump cooling properly in those hot summer months is a must to maintain a comfortable home. When your heat pump won't cool, you want to get it up and running again as quickly as possible. Try these simple troubleshooting techniques to get your heat pump back to work.
Step 1 – Check Your Settings
If your heat pump worked fine when it was chilly but is failing you now that warmer days have arrived, the first thing to check is that the thermostat is turned to cooling and set on automatic. The switches are generally located on the side or bottom of the unit; this is the simplest possible solution. If this doesn't solve the problem, try turning the machine to “fan only”, to make sure that your fan is running properly. Be sure to keep the thermostat at a temperature setting that is comfortable for you; if the setting isn't low enough, the heat pump won't kick on.
Step 2 – Check Your Filter
Your filters have to be clean in order for your heat pump to work properly. You should change them monthly during heavy use seasons. If either the filters are clogged or there is debris around your compressor, that could explain the cooling problem. Use a low pressure hose to wash out the outdoor compressor. Often this is all it takes to fix a cooling problem
Step 3 – Defrost the Heat Pump
Sometimes the energy efficiency settings on the heat pump will prevent the defroster from working long enough or often enough to keep your heat pump defrosted. Try running the “fan only” setting for an hour or so to defrost the heat pump. If this is a recurring problem, consider moving the outdoor sensor to a more ideal location, closer to the coil's outtake.
Step 4 – Check Your Power Source
Check your fuse or breaker box to make sure that the heat pump is receiving power. If the heat pump starts and stops, or continuously flips the breaker, you may have either a problem with your heat pump's compressor, or a problem with your home's electrical wiring. At this point, it is advisable to have an electrician come out and take a look at the problem.
Step 5 – Change the Batteries on Your Thermostat
Electronic thermostats often need frequent battery changes. Try changing the batteries on your thermostat to see if it improves the functionality of your heat pump.
Step 6 – Add Refrigerant
Low refrigerant levels can limit the functionality of your heat pump, or even cause it to fail. Adding refrigerant requires a special license, because handling the materials is extremely hazardous for those without specific experience and training in proper handling and retrieval techniques. The EPA also has specific guidelines for the disposal of refrigerant, which is harmful to both humans and wildlife. At this point on the list, it's time to call in a professional.
