Login Error
Close
How to Unclog an Automotive Air Filter
by DoItYourself Staff
what you'll need
  • Owner's manual
  • A vacuum
  • Old rags
An automotive air filter can become clogged with dust and other debris. A clogged air filter can reduce the fuel efficiency of a vehicle. It is important to keep your air filter clean. You can clean your air filter yourself in just a few minutes.
Step 1 – Removing the Air Filter
Open the hood of your vehicle. Locate the air filter. If necessary, check your owner's manual. Remove the filter cover. You may need to pull up some clamps or loosen a nut to do this. Pull the air filter out from the cover.
Step 2 – Cleaning the Filter
Tap your air filter on the ground to remove any loose dust and debris. Use your vacuum cleaner to suck out the rest of the dirt from the air filter. Vacuum all of the dirt that is in the compartment of your vehicle where the air filter sits. Use an old rag to wipe out the compartment.
Step 3 – Replacing the Filter
Put the air filter back into position. Secure the cover over the air filter, making sure to put the clamps into position or to tighten the nuts. Close the hood of your vehicle.
 forum activity
