A compost thermometer is an item that you should have on hand to produce the most nutrient rich compost material that you can. The thermometer will take the temperature of the middle of the pile to determine when it is best to turn the pile.
Proper Aeration at the Right Temperature
There are a range of temperatures that are optimal for the compost pile to decompose properly. The temperature should be within a range of 105 to 145 degrees Fahrenheit. When the temperature begins to go above this range, you should turn the pile. This will help you to create the best possible material for your garden.
There are some other things that you can do to make sure that your pile is decomposing properly such as keeping it damp and moist. Usually the pile will be kept damp through natural means, but you can add to the moisture by applying a fine mist of water. The bacteria and bugs that are decomposing your materials need the moisture to thrive and do their job.
Maintaining a healthy temperature for your compost will ensure that you get the best possible results from your efforts.
Questions of a Do It Yourself nature should be submitted to our
