How to Use a Rotary Laser Level
what you'll need
- Rotary laser level
A rotary laser level is a tool used in many construction works. It helps guide the construction worker to level out the entire floor plan of the room or even a building, so as to make a balanced and leveled out design and finished product. For those who are into redecorating their room or house, you can make use of a rotary laser level, as it is easy to use and helps you work on the leveling of your construction work faster than without a level.
Basically, there are two types of levels, one is a fixed level and the other is rotary. The rotary level is more beneficial than the fixed level, as it can create a beam of 360 degrees around the room, even sometimes including the ceiling and floor level so that you can get a more accurate work. It is great for establishing heights at around 50 ft to 100 ft distances. Using the rotary laser level is fairly simple. Just follow the steps in this guideline.
Step 1 – Set Up Your Rotary Laser Level
Prior to using your level, check first the manual and read up on how to install it. Your rotary laser level may have an accompanying laser detector, called receivers, when it is for outside use. The best way to set-up your level is with the use of a tripod. Some level manufacturers have their own tripods sold separately from the level. So, prior to purchasing your level, make sure you have also get the tripod. If you have no tripod, try to set up the level with any make-shift devices, such as a bucket, a sawhorse, a small table, or any elevated semi-level areas.
Step 2 – Self-Leveling After Turning It On
It is best if you were able to purchase an automatic level where you do not need to calibrate any measurements. This will allow you to get a more accurate and efficient measurement rather than adjusting the calibration manually. If ever you do tend to calibrate it yourself, make sure that you have set it to the standards or you will be getting wrong measurements. Consult the device’s accompanying manual to further guide you with the use of the device. If used during daylight, the receiver will beep to inform you that it has made a connection with the laser, as you cannot see the laser light during the day. Check first the functionality of the receiver at a near distance before moving farther.
Step 3 – Measure Away
Start the measuring process by directing the laser towards the wall where you want to install cabinets or windows. Mark the areas pointed by the laser in order for you to note those areas when you will begin your work. With the laser guiding your point of references and aligning your installations in your room, your construction work will be quick and efficiently managed.
