Login Error
Close
How To Use A Solar-Powered Generator
by DoItYourself Staff
A solar powered generator can be used to run all the electrical gadgets and lights in the house.  A solar powered generator is just like any other generator, but it makes use of the solar energy for power generation.
Components of a Solar Powered Generator
A solar powered generator consists of the following components:
  • Solar panels
  • Power Inverter
  • Deep cycle batteries
These components work together to collect, use and circulate the solar energy.
How Can I Use A Solar Generator?
Solar generators can be hooked up to essential electrical circuits in your home. In the event of a power outage, the generator would take over and supply power to your home.
Most people will use the generator only on what they consider essential, such as lights, heating or cooling, and refrigeration. This helps to maintain the charge the panels have picked up.
How Does a Solar Powered Generator Work?
You need to keep the solar powered generator in a place where direct and maximum sunlight is available. The solar panels collect the energy from the sun and convert it in to DC power.
The power inverter will convert the DC power of the solar panels into AC power. This ensures that the generator is not over charged. This solar electricity can be stored for future consumption. The DC power allows continuous operation of the solar powered generator.
However, there could be times when the power supply is disrupted due to bad weather conditions like a hurricane or tornado or even due to heavy snow fall. During inclement weather, a solar powered generator can be very useful.
Advantages of Solar Powered Generators
Solar energy is a pure form of energy, since it uses the direct rays of the sun. Therefore, it is environmental friendly. There is no pollution with a solar powered generator. By using solar powered generators you are helping in keeping the environment pollution free.
The solar power generator can be recharged every day, by simply keeping it in the sunlight.
In case of power failure, you don’t have to worry about supply of natural gas or other energy utility as you can easily use your solar powered generator.
Low maintenance cost of the generator makes it an attractive option. Once installed properly it will last years with very little maintenance required.
Solar power is completely free. After you spend money on the initial installation costs, you don’t have to worry about additional costs associated. So, if you thinking of cost control, go for a solar powered generator.
Power generation is comparatively cheaper as compared to other types of generators.
You can use these generators to run essential equipment in your home or office.
Disadvantages Of Solar Generators
You can recharge the solar powered generator only in presence of sunlight. When the sky is too cloudy, or in case of bad weather, when it snows for long durations or when a hurricane or tornado strikes, you cannot recharge your solar powered generator.
You can charge the generator only during day time.
The costliest component of solar powered generators is the solar panels. If the panels get damaged, replacing them can be expensive.
Looking to purchase a new generator? Check out our Generators Buyer's Guide.
 forum activity
