Login Error
Close
How To Use Green Insulation In Your Home
by DoItYourself Staff
Using green insulation is one of the most eco-friendly projects you can do in your home. Whether or not you already have standard pink fiberglass insulation, you can benefit from the efficiency of green insulation.
These new green insulation types are healthier for you to install and have very little impact on the environment. However, the real benefit is in the efficiency of the insulation. In nearly every case, the different types of green insulation work better than the standard insulation.
Different Types of Green Insulation
In today's age of recycling, and reusing many of the different products that we have today, there are several different types of products that can be reused as insulation.
•Recycled Denim - This green insulation is made from old blue jeans that are shredded into tiny pieces. It is made of cotton so there isn't any nasty chemicals that will be given off from it. Recycled denim also installs very easily without any need for protective equipment.
•Sheep Wool Insulation - Something that has been used for centuries to create organic clothing, it has taken a long time to create insulation out of it. Sheep's wool is a tremendous insulator that is starting to catch on.
Install Heavily in Attic
The place in your home that is going to lose the most heat, and energy loss, is through the roof. In the winter time, a good percentage of your home's heat is rising up through the rafters and out the attic. This can be stopped by covering the attic with a heavy layer of green insulation.
Wrap Hot Water Pipes
In an effort to stop the heat loss from your water pipes, you can buy specially designed green insulation for your pipes. As the hot water heater continues to heat water, it is being lost through the pipes as it sits there. Wrap the water pipes, and the water heater with thick insulation to keep the water at temperature keeping the heater from turning on.
Install in Exterior Walls
Having green insulation lining all your exterior walls is your barrier against the cold weather assault, and wind, during the winters. The cotton, paper, and foam insulation that makes up several of the green options, are tightly compacted and act as a much more efficient barrier than fiberglass insulation. Another great benefit is that they do not sag over time leaving areas that are unprotected.
Staple or Blown In
When insulating your home with green insulation you can pretty much install it as you would fiberglass insulation. They are created much the same way as regular insulation with tabs you can stable to studs, or rafters. There is also green insulation that you can blow in easily that will expand as it dries.
Save Money with Green Insulation
Whether you are using it as roof insulation, or lining your walls, green insulation varieties will not only save you money, but also keep your family safe from the toxins that are in standard insulation products. Installation is done easily without any special equipment, and they will last much longer.
 forum activity
