How To Use LED Grow Lights
what you'll need
- Indoor plants
- Electrical sockets
- Electrical outlet with timer
- LED grow lamps
LED grow lights are starting to be used more and more when it comes to growing indoor plants. This is mainly because they use less energy while producing a more powerful light. You can also count on your LED light to last a lot longer than any other light, such as fluorescent lights. You can choose several different colors to mimic the sunlight. You will not need to get a new kind of electrical fixture or ballast for LED lights.
Step 1: Determining Necessary Light
Before you begin you should do a little research on your plants. This will help you to determine how much light you are going to have to use on them. Once you have figured this out, you can choose the wattage of the LED light as well as the color. You can also set the duration on your electrical outlet timer. Red and blue LED grow lights are usually what most plants respond to. Research has been done that states that the best ratio for your LED lights is 80 percent red and 20 percent blue. If you are having trouble seeing your plants, you can switch out some of the blue for white lights without causing harm to your plants.
Step 2: Where to Place Your LED Lights
Depending on the size and the kind of plant that you have, this will determine how far you should hang your LED lights above them. They can be placed as close as 5 inches and as far away as 20 inches. Do your research before you hang your LED lights.
However, the ultimate goal when it comes to getting the right kind of light for your plants is this. The greens should be bathed in light all the way to the edge. But the light should never spill over. No light should be wasted for any of the nearby places without plants. As your plants grow and change their shape, you are going to have to adjust the heat of the lights.
Step 3: Dark Periods
Some lights don’t require constant light. For these you are going to need a timer. Get your plants set up on a schedule. If they are taken off of that schedule at any time it could hurt their growth. Regardless of how much sun or darkness they need, you will be able to set the timer up perfectly to your plants needs. The hard part will be determining how much light they will need versus how much darkness. Once you have determined how much light your plant needs, setting up the timer is simple. Be sure to read the instructions carefully to ensure that it is done correctly.
Step 4: Safety Tips
You should be sure that you never look directly at LED lights, especially at a close range. This could cause you serious eye damage. Also be sure to handle the bulbs that have been lit carefully as they will be very hot.
