Login Error
Close
How to Use Plywood to Make Ceiling Medallions
by DoItYourself Staff
what you'll need
  • Primer
  • Plywood
  • Caulk
  • Drywall screws
  • Measuring tape
  • Saw
  • Drill
  • Epoxy
  • Safety goggles
  • Ladder
  • Gloves
  • Paint
  • Paint brushes
  • Tarp
Ceiling medallions are an amazing asset to any room. They tend to bring the rooms decor together and give a finished look. If you are planning on moving to a new home or just remodeling your own, a plywood ceiling medallion is a great addition. Here is a quick step by step guide with the tools and materials that you will need to do this project on your own.
Step 1 - Measure
The first step is to decide what size you want to make your plywood ceiling medallion. The best way to measure is to get the dimensions of both the length and width of the ceiling. Then multiply those numbers together and get the total. Then, take that number and divide it by 7. This number is just a general estimate, however, it will work to find a medallion size that is appropriate for the size of the room and then you can eyeball it from there to see what you like personally. If you have a shorter ceiling that is less than 9 or 10 feet, then a smaller medallion would look better and make sure that the size that you choose works with the light fixture that is already in place. Once you are done with the medallion measurements, you will want to check out the light fixture or fan there and measure that for the inside. Use pencil and paper to mark down the dimensions as you work to help get the supplies.
Step 2 - Cut Plywood
Before cutting anything make sure that you are wearing safety goggles and gloves to protect yourself. Use a saw to cut the plywood into a circular shape in the dimensions that you have decided on. You will also want to cut out a center the size of the light fixture that will be going in.
Step 3 - Decorate
You can now prime and paint the medallion how you would like. Place a tarp down if you are working inside because painting it gets messy since you will need to more it around to get every spot. It is best to allow the primer to set for an hour or so and then use a paint brush to add the paint color that you like. Allow it to dry completely before touching or working with it any more.
Step 4 - Attach
When the ceiling medallion is all finished, use a ladder and a partner to attach it. Paint the back of it, the part that attaches to the ceiling, with epoxy adhesive. Then, carefully apply the medallion to the ceiling in the correct spot. Hold it there for several minutes and then allow it to dry completely. Once dry, drill holes and insert drywall screws to hold it in place.
Now that you are finished, you can attach the light fixture inside and test it out.
 forum activity
