Login Error
Close
How To Wash Sticky Polyurethane Off Your Hands
by DoItYourself Staff
The major downside to using polyurethane varnish is that not all varieties clean up with soap and water. This can result in a messy cleanup process. But if you prepare in advance, you can make it as easy as possible.
Step 1 - Read the Can
The back of the polyurethane can will tell you exactly what to use to clean it up, usually it will be mineral spirits or paint thinner. Make sure you have some.
Step 2 - Prepare
You may not want to clean up right in your kitchen sink (although you can if you so choose). You'll need:
  • Solvent
  • Shop rags or paper towels
  • Hot water supply
  • Strong hand soap
  • Hand lotion
  • Protection for any painted or varnished surfaces that the solvent may come in contact with.
Step 3 - Apply the Solvent
When you are ready to clean up and your hands are sticky with polyurethane, you'll need to cut it with the solvent. Apply solvent liberally to your hands, and then use your shop rags or paper towels to thoroughly and methodically wipe down each part of your hands.
Step 4 - Remove the Solvent
Soap your hands with comfortably hot water, lathering well.
Step 5 - Repeat If Necessary
You may still find some sticky spots you missed. Dry your hands and repeat steps 3 and 4.
Step 6 - Clean Up
Dispose of towels or rags appropriately.
Step 7 - Moisturize
Solvents are very drying to the skin. Apply hand lotion liberally.
 forum activity
