Login Error
Close
Husky Work Bench Buying Guide
by DoItYourself Staff
Are you in the market to purchase a new husky work bench? If you are, then be sure to read through the below buying guide. There are different models and types of husky work benches and you will be sure to find one that meets your needs.
Basic Husky Work Bench
This model is great for someone that does not require a lot of storage solution or space. It has a confident design, fits compactly in most spaces and is an ideal work bench for someone that just needs a surface or a bench space to work off of. This work bench is sure to last.
Basic Husky Work Bench with Shelf and Drawers
This work bench will help you to organize yourself. You can use the drawers and the shelves to store away your tools and equipment sets. The work bench gives you ample room and surface area to work. Designed with steel inserts, it is a durable and strong choice for the busy do-it-yourselfer. The shelving is strong enough to store large bulky items and power tools or chemicals. This is an all-around great choice.
Husky Work Bench Add-on Options
There are many different single add-on options you can look to purchase. Everything from extra drawers, under the bench roll-out cabinets and top mounted headboards. Be sure to check into all the options for your next purchase.
 forum activity
