Login Error
Close
Importance of a Recessed Lighting Trim
by DoItYourself Staff
A recessed lighting trim plays an integral part in the overall lighting qualities of a recessed lighting fixture. A recessed lighting fixture is installed within an existing structure in the house, most commonly the ceilings. It is called "recessed" because a substantial part of the fixture is inserted within the installation base. The lighting effect is not pronounced; therefore recessed lighting is a subtle form of lighting that is recommended as a decorative option.
The Importance of Recessed Lighting Trim
Essentially all recessed lighting fixtures are made up of three basic components: trim, housing and the light bulb. The trim is the external, visible part of the fixture. It is often called the frame. Choosing the appropriate trim is critical because it affects the aesthetics, lighting attributes and price.
Aesthetic Compatibility
Since the recessed lighting trim is the most visible part of the fixture, it should be compatible with the décor of the surrounding room. The contemporary home décor market offers recessed trims in various designs. You can choose from recessed lighting trim made of glass, plastic, acrylic or metal. Trims are also classified as retro or modern.
You may customize recessed lighting trim to complement your home’s interior. Most retailers offer staining or painting the trims according to a client’s color preference.
Lighting Attributes
The kind of recessed lighting trim you choose will affect the overall illumination effect. You should inform the retailer about the kind of lighting affect you desire.
You can buy trims with reflectors, a lighting accessory recommended for homeowners who want brighter lighting from their recessed fixtures. Trims also affect the degree of glare. Slightly bigger trims can better shade away the glare. However, a bigger size also compromises the brightness to a certain extent.
Special recessed lighting trim, like the wall-wash trim, are used for producing wall-washing or spread lighting. Here, the light is spread across a wall in a distinct, fading style. This effect usually works best for living spaces or for walls near an open kitchen. These trims have an expensive, eyelid type of cover for producing the desired effect.
Recessed lighting trim can also produce task lighting, which narrows the beam and directs it toward a certain section of the room.
Ambient lighting trims are the most common. They are often sold as open trims.
Pricing Consideration
Prices for most retailed fixtures are largely dictated by the kind of trim you choose. You can buy recessed lighting trim in an exhaustive range of size and style options, often with warranties.
The trim also affects the ease of installation. You will easily install most types of recessed lighting fixtures. However, the retrofit trim can be demanding and is best handled by professionals—an added expense.
 forum activity
