Login Error
Close
Incandescent to Fluorescent Watt Conversion
by DoItYourself Staff
The fluorescent watt conversion is generally lower than an equivalent incandescent bulb. The latest boon to hit the lighting industry is the introduction of the fluorescent bulb that produce more light, emit less heat and last 8 to 10 times longer than an equivalent incandescent bulb.
Cost of Fluorescent over Incandescent
Although the cost of acquiring a fluorescent bulb is higher than an incandescent bulb, fluorescents produce more light output while consuming less energy in the process. The common misconception is that a fluorescent bulbs cost negates any savings made on your part but this is not true. Remember that the long service life of fluorescents is enough to justify the price.
Fluorescent Watt versus Incandescent Watt
To serve as an example, a 60 watt incandescent bulb that produces a light output of 800 lumens is equivalent to a fluorescent bulb which consumes only 9 to 13 watts of electricity. As mentioned before, the benefits not only extend to overall power consumption as fluorescents last 8 to 10 times longer than an incandescent bulb. With striking figures such as these, making the switch from incandescent to fluorecent bulbs is an easy and practical way to save energy while maintaining a bright and beautiful home all year round.
 forum activity
