Infinity Pools: Pros and Cons to Installing One in Your Backyard
While infinity pools are a luxurious and attractive feature for many different yards and landscapes, they also have a number of different downsides as well. Before you consider installing this type of pool in your yard, consider the potential risks and benefits. This can help you to decide if it's better to install an infinity pool, a standard type of pool or no pool at all in your yard. Read on for some of the pros and cons of adding an infinity pool on your property.
Pros of Installing an Infinity Pool
One popular pro of installing an infinity pool in your yard is the ability to swim in a pool on your own property. Like standard pools, infinity pools can be used for recreational purposes. They can also be used to exercise and are a suitable place for fun for people of all ages. Additionally, infinity pools can be customized to a design that will meet your particular needs. For example, if you have a young child, you can build your pool to include a wading section where your child can play.
Infinity pools also offer amazing views. When installed properly, these pools can provide a unique vision of the surrounding landscape. When perched on a hill, the vanishing edge of the pool can overlook the view and provide a natural and attractive aesthetic as well. Also, infinity pools are popular for ocean views or desert schemes.
In some ways, infinity pools are easier to maintain than standard pools because they have a filtration system that helps to pump water up from the catch basin pool to the main pool. This helps to reduce the need for cleaning out the pool or ensuring that the water does not stagnate. The constant motion of the water continually cleans and filters the water.
Cons of Installing an Infinity Pool
While infinity pools are attractive and fun, there are many potential downsides as well. In some ways, these pools are more dangerous than standard types of pools. The exposed edge is easy to fall over and may result in injury. Additionally, an infinity pool might not be the best choice of pool to install in your yard if you don't have a natural sloping landscape. An infinity pool may not appear to be as spectacular in an area in which it doesn't overlook a larger space.
One of the biggest and most prohibitive cons of installing an infinity pool in your home is the cost associated with it. In addition to the main pool, you'll have to install at least one smaller catch basin pool as well as a system which will feed the water back up into the main pool. The cost of installing these pools can be tens of thousands of dollars alone. Additionally, maintaining an infinity pool costs a great deal of money. The cost of water, electrical costs, chlorine, other chemicals and tools that are necessary to maintain the purity of the water can be expensive.
