Login Error
Close
In-Ground Pool Installation Tips
by DoItYourself Staff
Inground pool installation is one of those home additions many people dread. An inground pool installation can literally turn your home upside down for weeks, and there's nothing you can do about it because an inground pool installation takes time. The entire process doesn't have to be difficult. The information below will share with you some tips on inground pool installation that will make your life easier.
Hire Reputable Businesses Only
It is very hard to do inground pool installation on your own, so it is important to hire people to do it for you. Nearly anyone can build a basic inground pool, but doing it right means a lot to the longevity of the inground pool. Only talk to companies that have at least five references that you can check on and verify. If they are local, it could prove beneficial to visit one or two of the references to see the work for yourself. You also want to make sure that they are fully bonded and insured so that you are protected from worker injury as well as mishaps with potential gas lines.
Choose the Right Materials
Like anything else you can buy, even pools come in several materials to choose from. The two most popular materials are either concrete or fiberglass. Fiberglass pools are typically less expensive than concrete, and they are also relatively easier to install. Less time means less expensive. Fiberglass pools are already molded to suit a certain size, both in length and in depth. A concrete pool can be created to any depth, size or design you want. You also have to decide on current cost vs. cost in the future. Fiberglass pools will require painting and refinishing every few years. Concrete pools can last over 50 years if you maintain them properly.
Zoning
Most people do not even think about contacting their local zoning offices prior to inground pool installation. They are under the misguided notion that because they own the house and the property it sits on that they can do anything they want on it. Unfortunately, that is not the case. Any addition to the home, including inground pool installation, needs permits and permission from zoning. Be certain you call the local permit and zoning office to ascertain what the rules are for your area.
The Right Location
Inground pool installation is one of those jobs that when once you decide to undertake it, you cannot change your mind. When you make the decision for where you want to place the inground pool, make sure it is a sound location. Choose an area where there are no electrical wires overhead. If you are not installing a pool heater, then use the sun as solar energy and build it in an area that gets a lot of sun. Windy areas will obviously ruin any heat generated by the sun, so keep the drafts to a minimum. High visibility is an important factor in inground pool installation, especially when you have children, as you want to be able to easily keep an eye on the pool area.
 forum activity
