Login Error
Close
Install a Door Drip Cap in 5 Steps
by DoItYourself Staff
what you'll need
  • Drip Cap
  • Galvanized Screws
  • Silicone Caulk
  • Exterior Paint
An exterior door drip cap prevents water damage to the door frame as a result of rain and snow. Installing a drip cap is a simple process that can be completed in a few hours.
Step 1
Decide if you will install a storm door. Most storm doors have a drip cap included as part of the installation kit. However, if you will not be installing a storm door, then you will need to purchase an individual drip cap.
Drip caps come according to the door size. Typical door sizes are 32, 34 and 36 inches. Purchase a drip cap according to the size of your exterior door.
Step 2
Set the drip cap channel at the top of the door frame. Center the cap as you place it on the frame.
Step 3
Apply a layer of silicone caulk to the drip cap. This will prevent water from going between the drip cap and the door frame and causing damage.
Step 4
Screw the drip cap into place with galvanized screws or the screws provided in the storm door kit.
Step 5
Apply a coat of exterior paint over the drip cap screws to blend them in with the exterior door frame.
 forum activity
