Login Error
Close
Install a Linen Cabinet
by DoItYourself Staff
what you'll need
  • Wood
  • Door
  • Hinges
  • Measuring Tape
  • Saw
  • Nails
  • Wood Filler
  • Putty
  • Sheet Rock
  • Sheet Rock Tape
You can gain significant amounts of extra storage by adding a linen closet to your home. It is a fairly easy do it yourself project. Follow the steps noted below.
Step 1 – Locate the Space
Decide where you want to locate your linen cabinet. Measure the space from the floor up to the ceiling. Generally, most spaces are anywhere between 7 and 10 feet in height. Plan to build your linen cabinet from the floor all the way up to the ceiling. This will give you plenty of space to store both your frequently used items and the things that you do not use regularly. You can easily put these items on the top most shelves.
Step 2 – Purchase the Wood
Take a trip to your local home improvement center. Purchase the lumber needed for this project. You will need to purchase 2x4s or 2x6s for the framing.
Step 3 – Cut the Wood Framing
Using a free holding saw or a table saw, cut the wood to size. You will need to cut four pieces for the frame. Refer back to your measurements. The pieces should extend from the floor to the ceiling. Next, cut the top and bottom frame pieces. There will be four pieces on the bottom and four pieces on the top. These are basically the stabilizers for your cabinet.
Note: Your cabinet should be at least 2 feet deep and 4 or 5 feet wide. This will give you ample depth and length to store all of your towels and linens.
Step 4 – Cut the Shelves
If you have not purchased pre-cut shelves, cut the wood now. Cut the shelves to the depth and the length you have specified in your measurements. Cut the number of shelves necessary for your linen cabinet.
Step 5 – Connect the Linen Closet Sides
Using wood screws and wood glue, secure the sides of the linen closet in place. Secure both the top and the bottom of the linen closet sides. Use at least four wood screws on each side to maintain the necessary amount of support and structural stability.
Step 6 – Install the Shelving
Mark the wood at the locations you wish to install your shelving. Using screws, install the shelving in place.
Note: Shelving should be installed at least 18 inches apart for adequate room in between shelving.
Step 7 – Add the Sheetrock
Add sheetrock to the exterior of your cabinet. If you have installed your cabinet against two sides of a wall (in a corner) you will only need one piece of sheet rock for the exposed side. Cut the sheet rock to size. Tape the joints and putty the depressions made from the screws. Sand down.
Step 8 – Add the Trim
Add the trim to your linen cabinet. Trim can be added at the top of the cabinet (like a crown molding effect) and down the sides. Add base molding to the bottom edges. Secure the molding in place with small finishing nails. Fill the holes with wood putty and sand completely.
Step 9 – Attach Your Door
Attach the door to your linen closet. Secure the hinges and check for proper operation.
Step 10 – Stain or Paint
Finish off your linen cabinet with a nice wood stain or paint.
 forum activity
