Login Error
Close
Install a Trench Drain to Prevent Flooding
by DoItYourself Staff
what you'll need
  • Measuring tape
  • Chalk
  • Shovel
  • Trench drain gutter
  • Tin snips
  • Wheelbarrow
  • Cement
  • Water hose
  • Water
  • Drain grate (easily available in hard ware stores)
  • Tool box
The best drainage solution to prevent flooding is to install a trench drain. After all, we would certainly not want high tide water to seep in to our house and destroy the interior. A trench drain was earlier associated with castles alone. Such is the efficiency and popularity of this form of drainage system that more and more homeowners are resorting to the same. It is a small moat or elevated strip of land that is used to surround your house. This elevated land helps to ward off flood water from seeping in. The best part about installing a trench drain to prevent flooding is that it can be done by you.
Step 1 - Taking Measurements
Use chalk and measuring tape to draw the size of the trench. Remember, if you are making a trench drain in front of the entrance, the trench should be at least 7 inches long. Ensure that the trench size is as per your house measurements.
Step 2 - Digging the Trench
Use a shovel to dig the trench 4 to 5 inch deep. Ensure that the depth is maintained throughout the length of the trench. Remove all the dirt and mud from the trench.
Step 3 - Making Way for Trench Drain Gutter
Make way for the trench drain gutter. Measure the gutter size and locate the place where you want to place it. Ideally, it should be placed at the ends of the trench drain. You can use tin snips to make space for the gutter. These gutters are readily available in any hardware store.
Step 4 - Leveling the Ground
Place the trench drain gutter at the desired place. Fill up the surrounding place with mud so that the gutter drain is level with the ground.
Caution: Ensure that the gutter drain is slightly lower than the ground level. This would help water to seep in easily.
Step 5 - Making Concrete Mix
Make a concrete mixture by mixing cement with water. It is advisable that you put all the cement in a wheelbarrow and pour water in it with a hose. Keep mixing the cement until you get the desired consistency.
Tip: Do not mix all the cement all at one time. Reserve some for later use.
Step 6 - Sealing the Gutter
Use the concrete mixture to seal the gutter. Ideally, the concrete should be poured on all sides of the trench drain. Ensure that 1/8th of the surrounding area is enveloped with cement. Allow the cement to dry for 1 day before you move to the next step. If you see that the cement has cracked, then reapply another coat of cement to give a finished look.
Step 7 - Covering the Drain with Grate
Place a trench drain grate on top of the entire length of the trench. This grate will not only cover the drain, but also allow residents to walk across the trench.
 forum activity
