Install Basement Insulation Around Windows
what you'll need
- Stripping
- Caulk
- Window insulation kit
- Tape
- Blow dryer
Putting basement insulation around the basement windows can be a very important task. Not only will the insulation prevent the loss of heat in the basement, it will also stop you from having to purchase expensive energy-efficient windows. To save the expense many people choose to simply add the insulation:
Step 1 - Draft Checking
Place your hands near the edges of each window to determine any air movement. If you feel any air, this will let you know that there are spaces through which cold air is entering.
Step 2 - Replacing
Take all of the old stripping from around the windows and replace it with new stripping. Be sure that all of the basement windows receive new stripping in order to make the job effective.
Step 3 - Caulking
Take the caulk and seal any spaces around the edges of the windows. This will definitely stop draft from coming through. If there is old caulk around the windows, remove it first before applying the new caulk.
Step 4 - Finishing
Apply the plastic wrap that is in the kit and cut it to fit the windows. Tape the plastic around the window and be sure to seal the edges tight; this will fully insulate the windows.
