Install Bathroom Tile With Time and Cost in Mind
When you decide to install bathroom tile, you should remember to keep the approximate cost and time needed to complete the project in mind. Please read the information below which will help you to determine how much time and money you should set aside in order to install new tile in your bathroom.
Time Expectations for Common Tile Sizes
The most common tile sizes for bathrooms are those measuring 8 by 8 inches and 4 by 4 inches. For an average size bathroom, which is usually 7 by 10 feet, it should take between 6 to 8 hours to install the larger tiles and 10 to 12 hours for the smaller tiles. However, if there is tile currently in the bathroom and it needs to be removed, the expected time will increase and could go up to as much as 16 hours.
Cost Factors Associated with Tile
The average cost for ceramic tile, which is the most common type of tile, is around $4 a square foot. For the average bathroom size, you will likely spend $280 just for the tile. More expensive tiles, such as stone and granite, can cost up to $150 a square foot. You could spend as much as $10,500 should you choose the more expensive tile options. Also, you must consider additional materials such as thin set, spacers, and grout which is used to install the tile.
