Install Cable Deck Railings in 7 Steps
what you'll need
- Measuring tape
- Pencil and paper
- Carpenter's level
- Wire cutters
- Wire crimper
- Adjustable wrench
- Open ended wrenches
- Cable spindles, available in a kit
- Phillips-head screws
- Screwdriver or power drill
- Long wood bolts and nuts
- Cable, 1 cm x 19 inch segments
- Support posts, wood, metal or vinyl-clad
- Hand rail sections, 2x4 planks cut to size, or same as support posts
- Tempered glass panels, cut to size, if required by building code
Sturdy cable deck railing on solid wood posts lends a rugged look to your deck and helps maintain a clear view of the surrounding landscape. Designs with slim metal posts add contemporary elegance to your modern house. Follow these directions to install your cable deck railing accurately to ensure its stability, safety and beauty.
Step 1: Check Building Code Guidelines for Your Municipality
Be aware that in many municipalities, cable deck railings are not permitted to be constructed as they provide footholds that make it possible to climb up and over the top support of the railing. Consult your municipal building codes to ensure that your cable deck railings will conform to safety guidelines. Rather than not install them at all, you may be able to reinforce one or both sides of the cable deck railing with tempered glass rather than replace them.
Step 2: Measure the Total Length of the Cable Railing Sections
Measure the total length of the cable railing sections. Keep the distance between them to a maximum 24 inches, to be supported by a post made of wood, metals with a powdered paint coating, tubular stainless steel or vinyl-coated aluminum.
Step 3: Measure the Height of Your Railing and Install Support Posts
Railings should be between 25 and 46 inches in height, including a top handrail if desired, measured from the deck surface. Drill holes through the deck to attach support posts with the long bolts. Secure them below the deck with nuts.
Step 4: Measure the Spacing for Cables
Plan for 5 horizontal cables 3½ inches from the top and bottom of a 25-inch high railing, 6 cables for a railing 36 inches high and 7 cables for deck railings up to 46 inches in height. Mark the cable placement as the center of a circle formed by the
Step 5: Attach the Cable Spindles
These trumpet-shaped metal fixtures hold the cable in place at both ends. They measure about 4 inches long, and each holds at least 1 inch of cable. Attach the base to the post with a Phillips head screw, and twist on the spike to the outside edge of the base.
Step 6: Insert the Cables
Push 1 inch of cable into each spindle. Use the adjustable wrench and wire crimper to compress the end of the spindle around the wire, and then hold and turn the spindle with the adjustable wrench at each end to pull the wire taut. Check each strand of wire cable is level before inserting the next.
Step 7: Attach Top Hand Rail
Attach a 4-inch wide top hand rail of the same material as the support posts, or accent any cable deck railing with a cedar or redwood handrail.
