Login Error
Close
Install Fresh-Air Intake Vents on Your Furnace Duct
by DoItYourself Staff
what you'll need
  • One hood for fresh air inlet
  • Hole saw
  • Drilling machine
  • Screws for wood exterior
  • Caulk for exterior use
  • Caulk gun
  • Duct
  • Duct fitting
  • One Collar for fitting at pipe mouth
  • Screws for metal sheet joints
  • Measuring tape
  • Aviation snips
  • Crimper for pipe
  • 1 Barometric air damper
  • Wrench which can be adjusted
  • 1 hanger strap for support
  • Caulk of silicone
  • Metallic tape or aluminum foil
The furnace ducts are used for circulating warm air in modern homes. The modern architecture focuses more on raising walls rather than natural openings for the movement of air. This results in the structure becoming airtight and leads to a build up of suffocating combustible gases inside the home. Fresh air from outside is taken in using inlet ducts. This fresh air is allowed to move out, which then is heated up by furnace to be circulated via furnace ducts.
However, the circulated warm air could become suffocating hence it is a smart choice to install vents for fresh outside air in your furnace ducts.
Step 1 – Choose a Spot for Intake Hood
Choose a place separate and away from any of the furnace, exhaust and dryer vents going into the home. This spot will be the inlet of the fresh air intake hood. A separate entry is necessary to avoid recirculation of suffocating gases.
Step 2 – Install the Hood
Use the hole saw machine to drill a hole. Slowly push the pipe above the fresh air intake hood. Now tighten the inlet hood on the walls of the home using the screws for wood exterior. Use any exterior caulk, should be of high quality, to caulk around the fresh air intake hood.
Step 3 – Create a Hole in Return Duct
Now use the aviation snips to make a 6-inch wide hole inside the return duct. Keep the hole adjacent to furnace pipe. With the hole in place, install the metallic collar for pipe inside the hole.
Step 4 – Install Duct
Place the galvanized duct between the pipe coming from the inlet lid and collar. Use metallic screws to tighten the joints between duct and collar. If there are any cut joints then use the crimper on the pipe to fit in the joints. Make sure that all the joints are fixed properly else, the fresh air circulation will not work.
Step 5 – Install a Barometric Damper
A barometric damper is installed to prevent any fresh air from entering the duct before the furnace becomes functional. The barometric damper is installed inside the intake hood. Keep the direction arrows of barometric damper directing towards furnace. It means that the fresh air will flow towards furnace.
Step 6 – Hang the Duct
The installed galvanized duct hangs using the support of hanger strap. Be cautious to choose a galvanized hanger strap, which will be higher in tensile strength and against temperature changes.
Step 7 – Insulate the Duct
The final step in this process is making the duct airtight. For this, caulk every joint in the duct. The duct is insulated further using a duct wrap. In this case the duct wrap used is the foil. It guarantees that the furnace duct will not sweat due to cooler air during the cold season.
 forum activity
