Login Error
Close
Installing a Basement Exhaust Vent
by DoItYourself Staff
what you'll need
  • Exhaust fan and vent
  • Saw
  • Protective goggles
  • Carpenters square and level
  • Pencil
  • Drill
  • Screwdriver and screws
  • Caulking gun
  • Latex caulk
  • Fiberglass insulation
Installing an exhaust vent in the basement is a must for most homeowners. Many basements don’t have windows or any other type of ventilation. Furthermore, water heaters, washers and dryers and boilers are often located in the basement, making this a place where humidity, condensation, gasses and stale air collects with nowhere to go. The best solution to this problem is to install an exhaust fan and vent system that channels condensation and stale air outside. Keep reading to find step-by-step instructions on how to do this job yourself.
Step 1 – Buy a Basement Exhaust Fan and Vent
Before anything else, go to your local hardware store and purchase an exhaust fan and vent system. To figure out which size fan to buy, just multiply your square footage by 1.1, and choose a fan that has a CFM rating of the same number or higher.
Step 2 – Identify Where to Install
Back at home, figure out where you want to install the fan and vent. Inside the basement, a good location for the fan is by the furnace. It should also be high enough on the wall that the fan will be above ground. Draw a square on the wall where you’d like the vent to go using your pencil, carpenter’s square and level. Drill a reference hole and go outside to identify where the air will be flowing out from the basement. This is where the exhaust vent will be located
Step 3 – Install the Exhaust Fan
Go back into the basement. Take your electric drill and drill several holes along the square that you traced out. Then, take your saw and cut in between the holes in order to create a large space in which to install the exhaust fan. Remember to wear your safety goggles to protect your eyes. Insert the fan according to manufacturer’s directions. Use you screwdriver and screws to mount the fan to the wall.
Step 4 – Install the Basement Exhaust Vent
You need to install the exhaust vent by going back outside and finding the reference hole. Insert the exhaust vent according to instructions. Seal the vent with your caulking gun and latex caulk. It is even recommended to seal the edges of the vent off with fiberglass insulation in order to prevent cold air, insects or other vermin from entering your basement.
Step 5 – Run the Wires
The final step to keeping the air in your basement fresh and clean is to get your exhaust vent system connected to a source of electricity. First, turn the power off in your circuit box. Next, run the wires from the exhaust fan to the basement switch box. Secure all wires with electric tape. Turn the power back on in the circuit breaker and test the exhaust fan to make sure that it works. Go back outside to ensure that air is being ventilated back through the exhaust vent in the proper fashion.
 forum activity
