Login Error
Close
Installing a Category 6 Cable
by DoItYourself Staff
A category 6 cable or "cat 6" is a cable used to network through the Ethernet on your computer.  This cable transmits voice and data at an Internet speed of 155 mega bits per second (or mbps). It transmits this data at a frequency of 550 mega hertz (or Mhz). Category 6 cables are made with 4 pairs of copper wire that are twisted. Each twisted wire pair is made from larger 23 gauge copper, as opposed to the larger gauged copper used for a category 5 cables. The smaller the gauge number is, the larger the wire size. The category 6 cables are designed specifically to carry Gigabit Ethernet connections.
Cat 6 Cable
The cat 6 cable helps reduce system noise. It has an RJ-45 connector on its ends. When different cable standards are mixed, the signal sticks to the lowest category cable. The signal strength will decrease with the wire length. A category 6 cable is a littler harder to install than the category 5 cable because it is made different. The copper wires are a little tighter in a category 6 cable. There are jacks and panels with enough sharpness to split the cable in pairs. This makes the installation easier. When installing a category 6 cable extra safety measures should be taken because of the sharpness of the split cables.
Step 1 – Find Ports
Find the Ethernet networking port on the network devices that will require the category 6 cable.
Step 2 – Connect Cables
Connect one end of the category 6 cable to the first device that you will install the cable. The end of the category 6 cable looks like a large phone jack. This is referred to as the RJ-45 jack. Connect the other end of the category 6 cable to the second networking device where you want to install the category 6 cable.
Step 3 – Check for Connection
Make sure that you cables are neat and are not in a location where they will suffer any type of damages. Check your network's ability to transfer between the two devices to make sure they are working together properly. They should have established a successful Ethernet connection.
Tips to Follow When Making Your Own Category 6 Cable
  • The RJ-45 plugs are made for solid conductors or either stranded conductors. Ensure that the plug you use matches your conductor type.
  • It is not easy to tell the difference between the two just by looking at them. The wrong type of plug can cause intermission problems.
  • If the cable does not work properly after installation, check to see if the wires are in proper order.
  • Ensure also that all of the wires extend fully to the end of the connector.
  • All of the pins should be pushed down fully.
 forum activity
