cancel
Job type :
Zip Code :
community forums
comments
Installing a Compact Electric Fireplace
A compact electric fireplace is a great option for people with space constraints who still want the look and feel of a fireplace. These units are easy to install. Because they don't require chimneys construction is not an issue. Just follow these simple steps and your compact electric fireplace will be ready to enjoy in no time!
Purchase the right model
The first step in a successful installation goes back to picking out the best unit for your home in terms of configuration, size and heat capacity.
While the average unit is about 26 inches, electric fireplaces come as small as 15 inches. If you’re planning on using the fireplace in a very small room, the smaller unit may be the best option, although it won't produce as much heat as a larger one.
The size and configuration of the fireplace will add constraints in terms of its placement in the home. A corner unit must always be placed in a corner, something to consider if you plan on moving the unit from one location to another or one home to another in the case of a move.
Assemble the surround
In most compact fireplaces the base and surround come preassembled. If not, i
t’s usually a pretty easy job requiring only a few screws and some brackets that usually come with the unit. Follow the manufacturer's instructions to assemble the surround.
Insert the firebox
The firebox in most compact electric fireplaces is generally integrated into the unit. However, in some models,
especially very ornate or decorative ones, the firebox is a separate piece that you have to secure in the surround yourself. Installing the firebox is usually just a matter of positioning the firebox in the surround and pulling a few wires through the back. Then just secure it with the screws or brackets provided. A simple screwdriver is probably the only tool you'll need.
Test the power and place the unit
Before placing your unit, test it by plugging it in and turning it on. You should see the flames immediately. Once you know it works, turn the unit off and unplug it and move it to its final location. If you’ve chosen a unit that bolts to the wall, securing it will be your last step.
member comments
Related Articles
Wood Pellet Stoves: Tips and Tricks
Wood pellet stoves are stoves that burn compressed wood for heating residential spaces. Wood pellets... read more
Integrated Wood Energy Systems for Sustainable Housing
This paper discusses environmentally sustainable housing principles and illustrates their application with three built projects... read more
Chimney FiresChimney Fires
What you should know about chimney fires, how to avoid them, and what to do... read more
articles we like
Postpartum Depression
Postpartum depression can bring on a wide range of emotions fill the expectant mother, and... read more
Many Options For Bay Window Curtains
Bay window curtains give privacy to bay windows, which are often the focal point of... read more
Fruit at the Core of Fruit at the Core of "Healthy You" Movement
Eating healthy is fast becoming a way of life for many Americans. Studies show people... read more
sponsored articles of the day
diy centers
