cancel
Job type :
Zip Code :
community forums
comments
Installing A Door Knob Plate
Installing a doorknob plate is crucial to installing a doorknob, as this plate is the part of the doorknob that holds the screws that keep the knob in place.
Step One - Measuring
Use the doorknob plate to ensure the hole to be drilled (or may already exist in the door) is the correct size for your doorknob. Measuring correctly is crucial to ensure proper functionality of a doorknob.
Step Two – Drilling Holes
Upon the installation of your doorknob, after drilling the necessary holes and ensuring proper alignment of the latch and holes, the doorknob plate will be placed under the doorknob on the outer part of the door. This way the lock mechanism can be screwed through it into the faceplate.
The doorknob plate should not be mistaken with the strike plate. This is installed in the doorframe to catch the latch, but is rather a part of the actual doorknob. Door knob plates also come in many different styles, but no matter the style, be sure to follow all directions and measure correctly to ensure proper installation.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
Painting Stylish Wall Borders
sponsored articles of the day
