Login Error
Close
Installing a Recessed Fixture Converter
by DoItYourself Staff
what you'll need
  • Converter kit
  • Drill
  • Flathead screwdriver
  • Phillips screwdriver
  • Step stool or ladder
Do you have a recessed light fixture you want to replace with a pendant light, ceiling fan or other type of lighting? You have two choices: The hard way, or the easy way. The hard way is a tough do-it-yourself project unless you have extensive knowledge of home wiring and electric building codes. It involves taking out the recessed light, re-wiring for a pendant, patching the hole you just created in the ceiling, and finally hanging the light. You could turn to a professional, but it will cost you anywhere from $200-$1200 per light, depending on the location of the light.
The easy way is a cheaper and much simpler solution. All you need to do is convert that recessed light into a normal pendant light using a conversion kit.
(Tools and Materials may vary depending on which type of converter you are using.)
Step 1 – The Converter
You can find converter kits at most hardware and lighting stores. There are also several companies that sell their kits online. Before you make a purchase, there are several things to consider. How big is the recessed light you are trying to cover up? There are different sized kits available for different diameter recessed lights, such as 4-inch kits, or 5 to 6-inch kits. Style is also something you need to think about before your purchase. Some kits come with the converter and a pendant light. If you already have a light fixture or ceiling fan in mind, try to find a general conversion kit that does not include or require a specific type of light. The last thing to consider is how heavy your new fixture is, and how much support it needs. The conversion kit should give you a maximum weight capacity. If your fixture exceeds the weight limit, talk with a professional about your options (such as adding your own support bars).
Step 2 – Preparing for Conversion
Once you get your conversion kit home, the first step is to prepare your recessed light. The first and most important step is to shut off power to that part of the house to avoid electric shock. Make sure the light is in the "off" position. Allow the bulb to cool before beginning.
Step 3 – Disassemble the Recessed Light
Remove the light bulb from the socket. Next, remove the trim around the recessed light. This is the piece that gives the light its finished look.  It is usually held in place by spring-loaded brackets. Use your flathead screwdriver to pop out the trim. Your recessed light is now ready for conversion.
Step 4 – Assemble the Converter
The next step is assembling the converter and attaching it to the recessed light. Since there are several different kits on the market, the details of this step will vary. Consult the manufacturer’s instructions that come with the kit.
Step 5 – Install Your Light
With the converter in place, your new light fixture installation should be the same as if you were placing it into a normal lighting assembly.  Again, before installation, make sure that the converter can support the weight of your light. Make sure the medallion and light completely cover the recessed fixture. You’re done! Turn the power back on and enjoy your new light!
 forum activity
