Login Error
Close
Installing a Toilet
by DoItYourself Staff
what you'll need
  • Wax seal
  • Toilet bolts
  • Toilet quick-connect supply line
  • Adjustable wrench
  • Flat-head screw driver
Installing a toilet can seem like a daunting task for the average handyman with minimal plumbing experience. Before you race to call a high priced plumber, you can follow these simple steps to install your own toilet like a pro.
Step 1 – Remove the Old Toilet
First, shut off the water supply by closing the valve at the bottom of the toilet. Then, flush the toilet and with an empty cup remove the water that is left behind. If the old toilet is a two-piece toilet, you can remove the tank first by removing the bolts that connect the tank to the bowl, which will make it easier to lift. Remove the toilet bolts and gently rock the toilet back and forth to break the wax seal.
Step 2 – Set the Bowl
For the next step you’ll need to set the wax seal over the flange. It’s crucial to make sure the wax seal is installed correctly so horrible smelling fumes don’t escape. Next, slide the toilet bolts in to the proper slots in the toilet flange. Simply lift the bowl and place it over the wax seal, pressing down firmly and evenly. It’s probably a good idea to grab an extra pair of hands to help guide the bolts through the holes in the bottom of the tank.
Step 3 –Install the Tank
 After you’ve set the bowl you can now install the tank by fastening the tank to the bowl with the hardware provided with the tank. Make sure you use the washers with the bolts to ensure a water-tight seal when securing the tank. You’ll have to use a flat-head screw driver to hold the bolt in place while you use the adjustable wrench to tighten the nut. The last step is to use connect the tank to the shut-off valve using the flexible quick-connect supply line.
Step 4 – Install the Seat
To install the toilet seat just secure the seat to the top of the bowl using the holes provided. The toilet seat will come with plastic bolts and wing nuts to secure it to the bowl. Again, you'll have to use a screwdriver in conjunction with an adjustable wrench to properly secure the toilet seat.
If you’re installing a new toilet in a basement the steps are pretty much the same with just a few minor differences. Two of the differences are the fact that you’ll be dealing with a concrete sub floor and a sump pump. But not to worry, there is no need to work directly with the sump pump and the concrete floor won’t pose a problem so long as your flange is in good shape.
Successfully installing a new toilet in your home is a great way to develop plumbing experience for the handyman homeowner. It's a job that does not require any complex connections but can familiarize a beginner with the basics of plumbing. After installing one of these, you’ll be ready to tackle the next plumbing project with renewed confidence.
 forum activity
